1994 Toyota Corolla
1994 TOYOTA COROLLA
ANTHONYALANIZ1713
Brakes problem
1994 Toyota Corolla 4 cyl Front Wheel Drive 200000 miles
my brake lights dont come on when i press the brake pedal i have replaced the brake swith and it still does not work i have also replaced alll the light bulbs.
Nov 23, 2008 at 9:56 AM
MMPRINCE4000
  • 8,548 POSTS
Inspect the light assembly in the trunk. They can lose connection and distort due to heat, make sure all the wires are tight and look for any burn marks.
Check for 12V at the light, if none and you have changed the switch, check fuses.
Nov 24, 2008 at 5:33 AM
