1994 Toyota Corolla 1994 Toyota Corolla barke issue
1994 TOYOTA COROLLA
16,400 MILES • 4 CYL • FWD • AUTOMATIC
LHOFMANN
I have a 1994 Toyota Corolla we purchased a few weeks ago. Occassionally while I'm driving it seems to loose speed and will not go over 25mph. When this happens the brake pedal seems very stiff and if i take my foot off the gas the car will loose speed very fast and stop. It will stay like this for a bit, then goes back to normal. Any ideas?
Mar 20, 2009 at 12:03 PM
MERLIN2021
  • 17,250 POSTS
Check the EGR valve for sticking open, does the check engine light com on?
Mar 20, 2009 at 2:49 PM
LHOFMANN
No, the check engine light does not go on.
Thanks for the reply.
Mar 20, 2009 at 3:48 PM
MERLIN2021
  • 17,250 POSTS
Let us know how you make out...
Mar 20, 2009 at 3:51 PM
MMPRINCE4000
  • 8,548 POSTS
Raise car put on stands and inspect front and rear brakes for any binding.
Also check fluid level in differential. Hook up power brake booster to vacuum and make sure it will hold vacuum, if not booster is bad, or a leak to either rubber hose or steel piping to it.
Mar 21, 2009 at 7:55 AM
