2004 Toyota Corolla A/C Relay
2004 TOYOTA COROLLA
90,000 MILES • 4 CYL • 2WD • MANUAL
DALE PICKENS
My A/c cuts off and when I wiggle a relay or fuse in the fuse box it will come back on. Could it be a faulty relay and if so would replacing this relay of fuse correct the poblem assuming all the pins are making connection. The A/C works fine other wise.
May 5, 2010 at 6:42 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
IF this is only when you wiggle the relay, then just don't touch it, if it is moving and cutting out due to body vibration, i would be fitting a new relay.
Mark (mhpautos)
May 5, 2010 at 7:12 AM
