Toyota air intake
TOYOTA COROLLA
LG2001
Click and Clack said many cars no longer locate the air intake on top of the engine and they run a duct to the air filter, which is often located behind a headlight or near a wheel well. If water gets sucked up through the air intake, the engine can be ruined. Where is the air intake on a 2006 Toyota Corolla located? I have a 2006 Toyota Corolla with 8,450 miles.
Nov 22, 2006 at 2:41 AM
CAPTAIN HANK
  • 32 POSTS
Locate the air filter housing and you can follow the duct. Most new car have it in the wheel well cavity.
Dec 24, 2006 at 1:28 AM
[quote:7c11b97dcf="lg2001"]Click and Clack said many cars no longer locate the air intake on top of the engine and they run a duct to the air filter, which is often located behind a headlight or near a wheel well. If water gets sucked up through the air intake, the engine can be ruined. Where is the air intake on a 2006 Toyota Corolla located? I have a 2006 Toyota Corolla with 8,450 miles.[/quote:7c11b97dcf]
Before that can happen-you must be half submerge in water-other than that a little H20 the air filter will absorb it before it makes it thru the TB and again it might decarbonize something within the combustion chamber.
Dec 24, 2006 at 5:56 AM
