P0741 code. would transmission flush fix this code?
May 30, 2017 at 10:54 AM
STEVE W.
CERTIFIED EXPERT
Probably not as that is a torque converter clutch circuit code. Usually it means the solenoid is bad or stuck.
It takes a scan tool and pressure gauge to test the system and trace the problem.
May 31, 2017 at 4:23 PM
KARRAH HEARNS
MEMBER
Thank you. My mechanic said he was going try to flush it first to see if that helps but maybe I should just tell him not to. (Can you even flush the transmission on a kia sportage? my friend said you can't because of the way it's built.) The dealership said they found metal shavings in my fluid and that I need a whole new transmission.
May 31, 2017 at 4:34 PM
STEVE W.
CERTIFIED EXPERT
You can flush it but it normally doesn't help. That trans isn't "user friendly" when it comes to service. That is what many auto companies are trying these days, replace a large component instead of repairing it.
