This is a big job. The cradle will need to be removed. As far as the directions, there is one set for both a 2wd and 4wd vehicle.
When you come to the 4wd info, you should be able to simply bypass them.
If you look below, the directions for both the removal and replacement of the transmission. Take a look through them and let me know if you have questions.
See pics below.
Jun 2, 2022 at 5:56 PM
