Torque Converter install
2001 SUBARU OUTBACK
175,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
ANTHONY BURTON
I replaced my torque converter, the original one had a stamp of 90 on it the one that was sent to me had a stamp of 150 on it. will it work? Everything is about it is the same it fit right in.
Jul 10, 2022 at 9:43 AM
Yep, it should work. Can I ask where you got the torque converter? My only concern is that the stall speed might be wrong.
Jul 10, 2022 at 4:40 PM
ANTHONY BURTON
I got it from a friend that through a rod, so he pulled the motor.
Jul 11, 2022 at 9:37 AM
ANTHONY BURTON
When I started it there was a high pitch squeal, so I shut it off and checked to make sure everything was hooked up. After checking I started it again, still had the squeal until I shifted it into reverse and then into drive. Then it had a whistle sound. any ideas?
Jul 11, 2022 at 11:26 AM
Hmm, the squeal makes me think it is a drive belt, they need to be tight on this car. Can you please shoot a quick video with your phone so we can hear the noise? That would be great. You can upload it here with your response. That way I can tell for sure.
Jul 11, 2022 at 2:57 PM
