The truck will crank but will not start. There is no spark?
1997 FORD RANGER
160,000 MILES • 3.0L • V6 • 4WD • MANUAL
PHELANSTAR
MEMBER
FOLLOW
The truck will crank but will not start. There is no spark. I have power at coils but no spark. Replaced the crank sensor wires coil and plugs.
Aug 12, 2018 at 9:41 AM
CERTIFIED EXPERT
This sounds like the PCM relay is not working. Here is a guide to help you test it and the location of the relay #4. Also, I found the engine wiring diagrams so you can see how the system works.
