Coming down the highway, the truck gauges when down to left, engine shut down. now i have no spark or fuel system, everything else work fine, lights, door locks, A/C, window switch, radio, gauges lights. All fuses and relay tested good 5 volts going to sensor like crank, TPS, etc. i put a scanner which turns on but have no communication. Gauge cluster self test work fine, given one code only of C code AA 00 which i found it mean no communication. i tested the ground and voltage at the PCM getting voltage, i check the bus line reads 00 with key on or off.
Aug 2, 2021 at 1:06 PM
