It will turn over like it is going to start, but does not?
1999 CHEVROLET TAHOE
180,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JEANSIMMONS993
  • 14 POSTS
It will turn over like it is going to start, but does not. Three days ago I pulled out my driveway put it it in drive pushed gas petrol and acted as if I ran out of gas and shut off. Hasn't started since. I have checked spark plugs, changed coil, ignition control module, crank sensor, checked voltage. Still not starting. Tested distributor, and button. Please help
Aug 9, 2019 at 7:35 PM
94 TRANSAM
  • 680 POSTS
Hi, I am sorry you are having issues. Lets see if I can help you.
It can be difficult to figure out whats wrong when a car just shuts off. so lets start at the basics. An internal combustion engine needs 4 things to start and run. If it wont one of these 4 is missing.
1: Air_ Make sure your air filter doesn't have a rats nest in it and can pass air freely.
2: Fuel_ Check your fuel pressure. If it is low it could be a filter or a failing pump or even a crushed line. Here is a link to test that:
3: Spark_ It sounds like you went through most of the spark components but you didn't say you had it. Here is a link to test for spark:
4: Compression: https://www.2carpros.com/articles/how-to-test-engine-compression
Give these a go and you should find your issue. Either way let us know how things are going fixed or not. Hope this helps you out! Rich
Jun 5, 2021 at 2:48 PM
JEANSIMMONS993
  • 14 POSTS
I have done everything you said. Still nothing. No spark no start. Replaced ICM, distributor cap button mass Air flow spark plugs wires.tested everything.
The ICM and PCM work together you might have a bad PCM. Here is a guide so you can check the wiring with the engine wiring diagrams below:
JEANSIMMONS993
  • 14 POSTS
the pink wire is showing continuity to the ground from the PCM.
