Okay. The failure is that the flange yoke on the 2003 failed and that let the U-Joint come apart. You are going to need a few more parts. First a new rear flange yoke like the first picture below and a new U-Joint like the second picture to replace the scrap one in your replacement shaft. Then you just need to unbolt the broken yoke from your truck. Remove the bad joint from the replacement shaft, then assemble all the parts to be able to reinstall it.
This shows how that rear yoke is bolted on. To start with you will want to mark the rear ends flange area so that you can install the replacement part so the U joint is in the same position it is now. See the edited one of yours. The orange are the bolts. You want to make the piece that flange bolts onto so the cap on the new U-Joint is in that same spot.
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
Now with that off clean the mating surfaces where the bolts go so there is no dirt or rust.
Getting the new yoke may take a bit of work, most of the chain parts stores likely wont have it or even be able to get it. NAPA might be able to or visit a salvage yard for one.
Now you need to replace the U-Joint in the end of the shaft and install the new yoke onto it.
Here are a few videos on that job. As ETCG says, you can usually get a U-Joint press at the parts store as a loaner tool.
https://www.youtube.com/watch?v=c2cPZMj6Gvw
https://www.youtube.com/watch?v=8VQQdrUi9wA
https://www.youtube.com/watch?v=uewFHe6H2Tw
If you have the two piece rear shaft and only have the rear section, you will want to get a different shaft that is complete, they are balanced as a unit so you cannot mix and match the two halves without causing a lot of vibration.
Jan 31, 2020 at 7:17 PM
