Vacuum lines and running issues
1988 LINCOLN TOWN CAR
87,000 MILES • 5.0L • V8 • RWD
MIKE LAWS
  • 5 POSTS
Just bought this car, first thing noticed before buying was every vacuum line was dry rotted and had fallen off of the ports.
Car ran perfect until couple of days ago when it was idling and just died.
Changed fuel filter as it appeared to be original filter, filter was clogged but fuel pump ran when turn key on and pumped fuel out the line as we checked it before hooking up filter inline.
Engine turns over freely, checked spark had weak spark changed coil and ECM on distributor. Still would not crank.
Tried getting engine to turn over on starting fluid and would not even hit.
Two part question need answers;
Anyone have vacuum line schematic or pictures of where to install lines?
Ideas on why engine wont crank?
Jul 16, 2016 at 6:45 AM
HMAC300
  • 48,601 POSTS
if you mean it turns over but wont run then scan for codes and check fuel pressure with a gauge. it may be vacuum line to map sensor can be why it wont run etc. auto parts rent gauge.
vacuum diagram is for federal if you do not live in California it will be the correct one.
Jul 16, 2016 at 11:55 AM
MIKE LAWS
  • 5 POSTS
Thanks, will check pressure at fuel rail and report back.
Jul 17, 2016 at 10:48 AM
Hey Mike here is another guide that might help you on the engine wont start problem.
Please let us know what you find so it can help others
Best, Ken
Jul 21, 2016 at 11:11 AM
MIKE LAWS
  • 5 POSTS
Checked fuel pressure it's at 38 lbs. followed testing procedures in the article
For the fuel pump relay test. Everything checks out good by this test. The yellow wire with green strip that is in position 1 as this article reads ohms out as having a short to ground, I unbolted the harness going into the computer and the wire no longer shows a short to ground. Any opinions on if I have a fried computer as it did run then died when it got hot and now won't start?
Jul 23, 2016 at 2:47 PM
HMAC300
  • 48,601 POSTS
it's probably a bad connection or the wire is shorted right by it and when you undid the bolt it straightened out. so check for a pinched wire or poor connection
Jul 23, 2016 at 4:11 PM
MIKE LAWS
  • 5 POSTS
I'll check it, thanks
Jul 23, 2016 at 4:14 PM
Please let us know how it goes,
Best, Ken
Jul 23, 2016 at 4:55 PM
MIKE LAWS
  • 5 POSTS
Rechecked the wiring harness, hooked the plug back into the computer and the yellow wire with the green strip showed short to ground, unhooked the computer again tested same white from the fuel pump relay to the plug at the harness and wire showed good. I did find out that the distributor isn't dependent on vacuum. Have pretty much ruled the computer as fried, also almost every wire going to the fuel pump relay wires were stripped back and corroded so assuming some jack leg before myself was trying to find an intermediate problem?????
Going to the junk yard to get a computer Monday.
Jul 23, 2016 at 7:43 PM
Okay let us know what happens
Jul 23, 2016 at 9:52 PM
HMAC300
  • 48,601 POSTS
I hope you fixed the shorted wire first as that may be the cause and not the pcm.
Jul 24, 2016 at 8:13 AM
