FUEL PUMP
Removal & Installation (EuroVan)
Obtain and record radio anti-theft code. Disconnect negative battery cable. Pull out carpeting from around access cover just right of parking brake lever. Remove access cover.
Disconnect wiring harness and fuel lines from fuel pump. Using Wrench (3217), loosen fuel pump screw cap. Remove flange and sealing ring from fuel tank opening. Loosen fuel pump by twisting it to left. Remove fuel pump from fuel tank.
When installing fuel pump, ensure that fuel gauge sending unit is installed with a frontal angle of 30 degrees and is not bent. Align mark on flange with fuel tank. To complete installation, reverse removal procedure.
Dec 5, 2008 at 7:18 PM
