Engine Performance problem
1995 Volkswagen Golf 4 cyl Front Wheel Drive Manual
I recently replaced the battery imediately after the car would loose power when the RPM's sincreased. It almost seemed like the fuel pump was going out or the clutch slipping. You can give it gas and it will start to drive normal then it will just loose power if you back offf and try it again the same thing will happen.
Mar 15, 2010 at 11:30 AM
