Sir:
I have a 1999 Passat in which the Engine Coolant Sensor "pops out". It has done this 3 times in the last week despite changing and putting in 2 new clips that hold it in place. The sensor is blue and inserts into a small coolant pipe towards the back of the engine. Firestone thinks that engine pressure is building up within the engine and looks to escape via the weakest point which is where the sensor is. What would be causing engine pressure to build up and if it is building up what is the likely fix. Firestone said they think a Gasket is going bad.
This vehicle has a rebuilt title on it and was previously rebuilt from a wreck.
Jul 14, 2009 at 11:34 AM
