Volvo C70 1999 95,000 miles T5 electric seat problem
1999 VOLVO C70
ZINGIBER
The drivers seat of my Volvo has stuck in a very awkward position - fully forward and fully upright. The seat will move forward when the lever is pushed up (to allow room for a passenger to climb into the rear seat) but this the only direction the seat will move in. I have checked the fuses but there does not appear to be a problem with any of these. Changed printed circuit board/switch assembly with one that is known to work but this has not resolved the problem. Any suggestions will be greatly appreciated.
Sep 29, 2007 at 11:54 AM
BMRFIXIT
  • 19,053 POSTS
[quote:b733d0dad7="Zingiber"]The drivers seat of my Volvo has stuck in a very awkward position - fully forward and fully upright. The seat will move forward when the lever is pushed up (to allow room for a passenger to climb into the rear seat) but this the only direction the seat will move in. I have checked the fuses but there does not appear to be a problem with any of these. Changed printed circuit board/switch assembly with one that is known to work but this has not resolved the problem. Any suggestions will be greatly appreciated.[/quote:b733d0dad7]
if all fuses ok
what about the relay
check that
Sep 30, 2007 at 6:42 AM
ZINGIBER
[quote:492c26d6ee="BMRFIXIT"][quote:492c26d6ee="Zingiber"]The drivers seat of my Volvo has stuck in a very awkward position - fully forward and fully upright. The seat will move forward when the lever is pushed up (to allow room for a passenger to climb into the rear seat) but this the only direction the seat will move in. I have checked the fuses but there does not appear to be a problem with any of these. Changed printed circuit board/switch assembly with one that is known to work but this has not resolved the problem. Any suggestions will be greatly appreciated.[/quote:492c26d6ee]
if all fuses ok
check that[/quote:492c26d6ee]
Thank you very much for this suggestion BMRFIXIT, will give it a go and see what happens.
Sep 30, 2007 at 10:59 AM
JIS001
  • 3,412 POSTS
Most likely problem is the spring on microswitch fell off. Lift up backrest upholstery and a bit and stick hand up and feel for the switch While pressing the seat control to move the seat look for the level on microscitch and move it until the seat moves to the position you want.
Mar 30, 2009 at 1:56 AM
