It sounds like the engine has overheated. Once engine has overheated, the headgasket weakens and allows the mixture of oil and coolant. Check dipstick, if dipstick is milky, there is probably too much coolant in engine already. Only solution you have is to remove the cylinder head and replaced the gasket. Make sure you have somebody due a pressure test to verify headgasket is leaking. Good luck!
Sep 16, 2010 at 6:52 PM
