I have had the a/c system charged and had dye to check for leaks - no leaks found. After the a/c stops cooling, and is turned off for 10 mins. it will cool again when turned back on.
I had it checked again today by another mechanic. He got it to stop cooling and checked the electrical to the compressor. He followed it back to a relay and replaced the relay with another but there was no power. He jumped the relay terminals and could make the compressor kick on. There was no power to the relay. He then followed the wiring further back and ran into some other relays and electronics.
Once the a/c stops cooling and the a/c is turned off for a short time and then turned back on, it will cool until it blows hot again.
He does not know where to go from here.....I hope you can help.
Aug 26, 2010 at 9:56 PM
