I have attached what the mechanics said. This is after I went to them and they said I had a leak around the oil pan tho no spotting on my garage floor. So i got a new oil pan gasket and then I had oil spotting on the floor! Took it back and they said:
Technician's comments:db 0.00
- oil pan not leaking any more but now there is a serious oil leak from above
The pan. About 0.2 quarts low on oil upon arrival. Oil cleaned off and UV dye added to trace oil using UV light.
- diagnostic shows oil leaking from top of timing cover and running down to the
front left of the pan. Requires camshaft seal. Recommend replacing timing belt component kit water pump and camshaft and crankshaft seals.
Replace timing belt kit with water pump and seals: includes ignition timing reset and db 784.83435.00349.83 replacing of external drive belts if needed. 0.00
Timing belt kit with water pump 219.95 2
Camshaft seal 19.99 19.99 One front crankshaft seal 9.99 9.99s1 valve cover gasket set 79.95 79.95s1
Coolant,longlife 19.95 19.95s 1
For a total (plus labor) of $784.83.
IF it is only the camshaft seal why do I have to have all of the other stuff (timing belt kit with water pump etc?).
Any suggestions?
Thanks,
J
Any suggestions?
Thanks,
J
Feb 1, 2017 at 5:15 AM
