Wheel bearing replacement
1997 TOYOTA T-100
185,000 MILES • 3.4L • 6 CYL • 4WD • AUTOMATIC
LARZY
Recently retired with time to spare and would like learn and do as much work as I can on our three vehicles. Before I tear the wheel apart can you tell me if this vehicle has a hub assembly with already installed wheel bearings or are they something I need to install separately? Thanks!
Mar 8, 2019 at 9:42 AM
Here is a video of the job being done with a diagram below to help you see how the assembly is built and the parts needed to complete the job:
https://youtu.be/mOyHFT0hoKc
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Mar 9, 2019 at 3:05 PM
LARZY
Thanks!
Mar 11, 2019 at 10:06 AM
Use 2CarPros anytime, we are here to help. Please tell a friend.
Mar 11, 2019 at 10:07 AM
LARZY
Thank you very much I appreciate it! I do have an additional question. I'm trying to remove a rusted on brake drum over the rear brakes on the 1997 T-100. Any tips would help. I've already doused around the lug holes with PB Blaster and tapped with a hammer. I wanted to try tapping the back edge out from behind but there is some kind of a dust cover with rounded edge circling and covering the back edge of the drum.
Mar 11, 2019 at 1:53 PM
This video should help:
https://youtu.be/UV0kfP17Co0
Mar 12, 2019 at 10:16 AM
LARZY
Thank you again! Appreciate it.
Mar 12, 2019 at 11:02 AM
