Wheel noise I hear brakes scraping?
2013 DODGE CHARGER
70,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
SKOOTER28
  • 98 POSTS
I hear brakes scraping and a slight bearing rolling around inside tire. I noticed it when checking tie rods and I moved the wheel side to side but not up and down and I spun the wheel and could hear loud scrapping noise and sounded like little bearings rolling around but couldn’t hear a growl noise.
Aug 27, 2024 at 1:30 PM
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. It sounds like you have a wheel bearing hub that is bad, or the brake pads need to be replaced. Here is how to check the brake pads. Check out the images (below). Please let us know what happens.
Aug 27, 2024 at 4:28 PM
SKOOTER28
  • 98 POSTS
I’m send it tomorrow morning is there a certain time you're up here?
Aug 27, 2024 at 5:59 PM
SKOOTER28
  • 98 POSTS
Okay, got it.
Aug 28, 2024 at 5:47 AM
I would remove the brake pads and caliper to see if the noise goes away, if so look at the brake pad anti rattle clips to see if they are touching the rotor. Thanks for the video, it helps.
Aug 28, 2024 at 8:32 AM
SKOOTER28
  • 98 POSTS
What about the other noise in the video?
Aug 28, 2024 at 8:34 AM
SKOOTER28
  • 98 POSTS
It almost sounds like a bad wheel bearing also but I’m not sure.
Aug 28, 2024 at 8:35 AM
Not to me, try removing the brake caliper and pads to confirm.
Aug 28, 2024 at 9:04 AM
SKOOTER28
  • 98 POSTS
Okay, so, if noise goes away, it’s in the caliper if it doesn’t go away most like melt the hub, correct?
Aug 28, 2024 at 9:08 AM
Yes. please let me know.
Aug 28, 2024 at 9:10 AM
SKOOTER28
  • 98 POSTS
I hope it goes away and thank you again.
Aug 28, 2024 at 9:15 AM
SKOOTER28
  • 98 POSTS
Here is another video I forgot to send with it.
Aug 29, 2024 at 8:35 AM
Thanks for the video, can I ask what was making the noise was it the brake pad anti-rattle clips?
Aug 29, 2024 at 10:21 AM
SKOOTER28
  • 98 POSTS
I believe so I haven’t had time to get the tires off yet I’m about to in a few but I think your right cause we had this caliper replaced by the dealer and I have a feeling they don’t do something right.
Aug 29, 2024 at 10:23 AM
SKOOTER28
  • 98 POSTS
But I also have movement back and forth on this tire but not on the other can you see anything in the video that I might be missing.
Aug 29, 2024 at 10:32 AM
The framing of the video is a little off for me to see everything, can you please reshoot it?
Aug 29, 2024 at 11:22 AM
SKOOTER28
  • 98 POSTS
I’ll reshoot it. I’m going to get someone to shake it while I record.
Aug 29, 2024 at 11:26 AM
Okay.
Aug 30, 2024 at 9:32 AM
