Wheel radio chips stolen suspension is off?
2010 SUZUKI GRAND VITARA
80,000 MILES • 2.8L • 4 CYL • 4WD • AUTOMATIC
SOPHIE BRUNO
  • 27 POSTS
I was robbed in flat house tire place on plain field NJ. Three workers positioned themselves on front and passenger tires and the owner deceptively punctured a tiny hole in a real tire resulting in a flat on highway 22. I wanted to buy a used tire. They scraped the radio magnetic strips off my two front tires. The electronic suspension is not working and says when i turn. The tire lamp is on all the time. I cannot fix it and cannot find online the wheel chips that communicate with the ECU. Can you help?
Dec 21, 2024 at 11:28 AM
The tire pressure sensor is part of the valve stem on the wheel. The sensor is on the inside of the wheel. To access it, the tire needs to be dismounted. (see pics below)
The OEM part number for the sensor is 4313054J22. Searching for Suzuki 4313054J22 on Google will bring up options.
Let me know if this helps.
See pics below.
Dec 21, 2024 at 9:13 PM
SOPHIE BRUNO
  • 27 POSTS
The wheels driver and passenger side had glued to the rim a strip of electromagnetic chips that talk to the computer and regulate the suspension system, what are these chips they are not wheel balancers that get clipped to edge of rim apparently the tire crew scaped the off the wheel with a spa hula , it affected the suspension. I wanted to upload a picture of the rim. I will try once again. I cannot upload a picture sorry.
Respectfully,
Sophie Brino
Dec 23, 2024 at 7:30 AM
I never heard of such a thing. Anything that would be external on the wheel would fail due to dirt, corrosion, and so on. What did they tell you was removed?
The only thing I can think of that would be electromagnetic would be a wheel speed sensor, but that isn't used for the suspension. Instead, it is used for traction control, anti-lock brakes, etc. If possible, upload a picture of what you are referring to. I'm really interested in seeing a picture.
Let me know. Also, I wish you and your family a Merry Christmas. I hope you have a great one.
Dec 23, 2024 at 8:17 PM
SOPHIE BRUNO
  • 27 POSTS
I'm trying to download photos of radio chips cannot download memory issues, and no Internet. Grandvitatra 2010 has electronic 4 wheel drive and suspension controlled by computer.
Dec 24, 2024 at 8:07 AM
Yep, we are going to need an image, I don't see anything like that in the wiring diagrams.
Dec 26, 2024 at 11:49 AM
SOPHIE BRUNO
  • 27 POSTS
Please I might be able to send the pictures of the wheel they are semi vondctor transponders. Need your email this cell phone has used up its memory.
Respectfully,
Sophie Bruno
Dec 28, 2024 at 7:29 AM
SOPHIE BRUNO
  • 27 POSTS
Hello friends,
I am now attempting to upload photo onl cips hat mak suspension adjust height and stabilize shocks on turns.
Respectfully,
Sophie Bruno.
Jan 19, 2025 at 11:23 AM
Those are wheel weights to help balance the tire, thanks for the image it helped.
Jan 20, 2025 at 9:56 AM
SOPHIE BRUNO
  • 27 POSTS
Okay, thank you!
About the Toyota Ken, I purchased a used computer for $20.00 installed it the Toyota started up. The open relay on old computer with key on lit the test light when cranking car never started. On use computer with key on the test light never lit until key was turned it lit up that is how I knew used computer would work.
Respectfully,
Sophie Bruno
Jan 20, 2025 at 1:44 PM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Jan 21, 2025 at 10:28 AM
