White smoke and oil leak after changing the air intake to turbo pipe?
2004 MERCEDES BENZ VITO
112,000 MILES • 2.1L • 6 CYL • TURBO • 2WD • AUTOMATIC
M_C_84
Had changed the air intake to turbo pipe part number A6395282082 as it had melted where it goes into turbo.
Once that was done, I took it for a drive and white smoke was coming out of exhaust. When I opened the bonnet, I noticed the oil had sprayed all over the engine… there was oil dripping on the floor and had a path (drops on road) not sure if it was a leak or just drips from when it sprayed!!
Any more questions I will answer thank you in advance.
Jul 13, 2023 at 2:37 AM
It sounds like the oil pressure or return line for the turbo is leaking. I would run the engine and without driving it use a flashlight to see if you can find the source of the leak.
here is a guide that can help:
https://www.2carpros.com/articles/engine-is-leaking-oil
Let us know what happens and please upload pictures or videos of the problem so we can see what's going on so I can help you fix it.
Jul 13, 2023 at 4:36 PM
