Window switch diagram needed?
2006 MERCEDES BENZ S550
100,000 MILES • V8 • 2WD • AUTOMATIC
PIMINHS3500
  • 11 POSTS
I would like to know the wiring diagram for the passenger side window switch. I'm trying to test it to see if it's just a switch that has failed because the motor works the regulator is fine, the fuses are good and so are the relays. Thank you
Oct 7, 2024 at 11:46 AM
The easiest way is to unplug the window motor and use a test light to see if it is getting power and ground while you work the switch. This guide can help:
Here is the window wiring diagrams as requested, check out the images (below). Let us know how it goes.
Oct 7, 2024 at 2:22 PM
