Windshield wipers only work on high?
2004 MERCURY SABLE
100,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
BRANDYY
  • 6 POSTS
My windshield wipers only work on high, and they do not park. There is no low or no intermittent they shut off where you shut them off at. I replaced the multi switch in the steering column and also the wiper motor I now have the GEM out. I was wondering if there’s a pin out diagram that I could test continuity on the pins from the GEM module that’s already out do you think this is the problem?
Apr 18, 2025 at 9:12 AM
Yep, you are on the right track, the GEM controls the wipers this way. I would replace it which should fix the problem.
Apr 19, 2025 at 10:49 AM
BRANDYY
  • 6 POSTS
They are not manufactured anymore. so, I have to try to go to a junkyard and find a compatible GEM mod for my 2004 Mercury Sable LS premium. Do you know what cars are compatible with the swap? I have power locks power windows sunroof so forth anti-theft my VIN number is. 1MEFM55S84A621815 in my research it says 2004 2005 say all LS or Taurus will fit.
Apr 19, 2025 at 11:25 AM
BRANDYY
  • 6 POSTS
Is it a common problem for these GEM modules to go on a 04 Sable?
BRANDYY
  • 6 POSTS
Thanks I really appreciate your help.
Apr 19, 2025 at 11:26 AM
BRANDYY
  • 6 POSTS
That is what I took out of the sable I have.
Apr 19, 2025 at 11:29 AM
Yep, that is it, here are the cars you that should fit your car:
2004-2005 Mercury Sable LS models (sedan or wagon, with similar options)
2004-2005 Ford Taurus SEL models (particularly ones with sunroof, anti-theft, power locks/windows)
Let us know how it goes.
Apr 20, 2025 at 11:10 AM
BRANDYY
  • 6 POSTS
Thank you.
Apr 20, 2025 at 3:17 PM
You are welcome, please use 2CarPros anytime we are here to help.
Apr 21, 2025 at 9:54 AM
