fuel pressure sensor wiring?
2007 FORD F-150
76,000 MILES • 4.6L • V8 • 2WD
TAYLOR&&88
I replaced the engine with a 2006 4.6 engine and my 2007 4.6 engine had 4 wires going to the fuel pressure sensor and the 2006 engine I replaced it with has 3 wires going to the fuel pressure sensor how do I connect the fuel pressure sensors.
Oct 14, 2024 at 8:36 AM
Yes, the fuel pressure sensors are different, can you just swap the sensors over to the correct one? There is no good way to wire the different sensors up. Here are the wiring diagrams and I can see a way of doing it to were you won't get a check engine light on. Check out the images (below). Please let us know what happens.
Oct 14, 2024 at 11:33 AM
TAYLOR&&88
I have a 2007 ford f 150 4.6 engine I replaced my engine with a 2006 4.6 and the fuel pressure regulator on my 2007 has 4 wires and the 2006 4.6 engine has 3 wires on the fuel pressure regulators has 3 wires how do I connect them
Oct 17, 2024 at 9:13 AM (Merged)
Did you see my first response? do you have any follow up questions?
Oct 17, 2024 at 9:14 AM
