Would like diagrams Auto Temp Control?
1999 CHRYSLER LHS
200,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
KEVINV1645
  • 15 POSTS
1998 Chrysler Concorde Auto Temp Control LGB BILL Car dealership MEMBER1998 CHRYSLER CONCORDE 6 CYL FWD AUTOMATIC 128,000 MILES
Nov 30, 2025 at 6:39 AM
Hello Kevin, here is the HVAC wiring diagrams and a guide to help with the testing:
Dec 2, 2025 at 9:20 AM
KEVINV1645
  • 15 POSTS
Awesome! These ATC'S :-(
Dec 2, 2025 at 10:02 AM
Yep, they can give troubles for sure, let me know what the problem was if you can :)
Dec 2, 2025 at 10:07 AM
KEVINV1645
  • 15 POSTS
Hi Ken L, The wire diagrams are very helpful, thanks! Looking for info specific to the pcb components, aspirator motor and the rest. Need to troubleshoot what fails. Don't believe its a BCM issue. ATC has no relay. Rabbit hole...I know. If you can help, great, if not, that if fine, also.
Dec 3, 2025 at 8:41 AM
Sure, I will help you, the first thing I would do is a CAN scan to see what codes are stored, please go over this video which should help us retrieve the codes.
CAN SCAN - https://youtu.be/u-4syLc-ifQ
Let us know how it goes.
Dec 4, 2025 at 8:12 AM
