Vehicle will not accelerate?
1996 JEEP GRAND CHEROKEE
110,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
SCXJ
  • 9 POSTS
The engine idles fine and will rev while neutral. When shifted into drive the vehicle will increase speed to about 25 MPH and then won't go much faster. I checked the fuel pressure, and it was about 45 PSI. Replaced both O2 sensors and the output shaft speed sensor. No OBD codes.
Thanks
May 7, 2023 at 2:36 PM
This sounds like you have a clogged catalytic converter but to be sure this guide can help us confirm the failure and I have included instructions on how to change the cat out in case you need it.
And this may help as well:
https://www.2carpros.com/articles/engine-has-low-power-output
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 8, 2023 at 11:23 AM
SCXJ
  • 9 POSTS
Okay, Ken, will do. Thanks for the input.
May 8, 2023 at 6:01 PM
Please let us know what you find.
May 10, 2023 at 10:47 AM
SCXJ
  • 9 POSTS
Ken,
Sorry I took so long to reply but you were correct, the converter was bad, running fine now. thanks for the advice.
Jun 24, 2023 at 10:21 AM
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jun 25, 2023 at 11:22 AM
