Rough Running Engine
1997 CHEVROLET SILVERADO
CNTRLFRK
  • 4 POSTS
Engine Performance problem V8 Four Wheel Drive Automatic 350000 miles
I have a Silverado C1500 with a 5.7L 350 Vortec engine. The engine will idle fine, but rough and will run so rough going down the road that it will literally shake the entire truck. Power has dropped and passing someone on the highway is nearly impossible.
I've changed plugs, wires, distributor cap, rotor, coil and fuel filter. I've even pulled both upstream O2 sensors to see if I possibly had a plugged Converter or Muffler, but this did not seem to help.
I know this truck has a lot of miles, but has always run well, and I've run out of ideas. The OBD scan shows "Manufacturer Ignition Control or Misfire" or something similar.
Any ideas?
Jun 24, 2008 at 10:32 AM
MERLIN2021
  • 17,250 POSTS
If you have the actual error code it would be helpful, but with 350,000? miles, it can be valve springs or other internal engine parts, start with a compression test, wet and dry! post results here...
This guide can help
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Jun 24, 2008 at 5:45 PM
CNTRLFRK
  • 4 POSTS
I only did a dry compression test. I can do a wet test if needed, I just didn't have anything handy to get oil into the cylinders.
I pulled out all plugs, stuck a screwdriver in the air intake to hold it open, and pulled the coil wire, then cranked the engine about 5 times and took my readings.
All were between 170-180psi, except cylinder 4 which was 162. I think these readings are acceptable considering the mileage on this truck.
Oddly the plugs from cylinders 5 and 6 were already very black (only in for two weeks) 6 was probably non-functional, as it was just a big glob of tar like substance on it. The engine does not use a lot of oil, and does not smoke.
I cleaned the plugs, checked the gap at .06 and replaced the plugs.
Now the truck won't start at all.
It does not seem to have any spark at all. Perhaps I have finally found my problem or maybe caused a new one. I double checked all the wires, and made sure I hadn't bumped anything while working and didn't see anything. With a screwdriver in the end of a wire, I got no spark at all when turning the motor over.
Is it possible I harmed the coil?
Is there a way to test the coil and/or ignition module with a standard multimeter?
Jun 26, 2008 at 8:25 AM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_Ignition_testa_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Ignition_testb_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Ignition_testc_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Ignition_testd_1.jpg
Jun 26, 2008 at 1:42 PM
CNTRLFRK
  • 4 POSTS
Thanks.
That is a very helpful and thorough, step by step procedure.
I kinda got thrown off on step 5, since the coil connector is not labeled, I assumed the 'pink' wire was 'C' and was chasing my tail until I looked at a wiring schematic. Then I assumed the 'black/wht' wire was 'C' since it was connected to the control module.
Assuming that is correct, I then proceeded down to until I got to step 12, where I did not show the 1-4 VAC, I only showed about .4 VAC on my meter.
I was not sure which connector was the 'VCM C3' connector, or which terminal was the ignition control (IC) circuit as described in steps 15-17, but I did disconnect all plugs from the module, then re-connect.
At this point, I am assuming it is the VCM since I do not seem to be getting hardly any AC control voltage to the Ignition Control Module.
If you have any other ideas, I would appreciate it.
Jun 27, 2008 at 8:43 AM
JWIN9569
  • 4 POSTS
Im having the same problem any fixes?
Mar 21, 2017 at 2:26 AM
These trucks had a problem with the injectors. Replace all of the injectors or just the ones over the cylinders with the black spark plugs.
Please let me know if you need anything else to get the problem fixed.
Best, Ken
Mar 23, 2017 at 7:45 AM
ALASKABOBB
Hi, I found out that the distributors on the vortecs wear out and cause these problems, some say only 100,000 miles. Mine is 243,000, but a new one fixed it. The OEM are plastic and the shaft starts to wobble as they wear and age and produce misfires.. Got a new one made from aluminum with cap and sensor for $34 on eBay, works great. I first had changed everything from sensors to filters and injectors, but it was the distributor. To set the new one on a vortec you have to use a scan tool, you are really setting the cam sensor since the engine is self timing. Instead I bought an app, Car Gauge Pro and a obd2 blue-tooth adapter I got on eBay (BAFX) and set mine for under $35,
Oct 19, 2018 at 9:38 AM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Oct 19, 2018 at 11:33 AM
KILMERONE
97 k1500 silverado 5.7 I had to crank the engine over for about 30 seconds until it finally started. after that it starts right up and seems to idle fine and it seems fine when i step on the gas in park. when i took it for a drive it spits and sputters. i changed plugs and wires but still spits and sputters. Please help!!!
Oct 19, 2018 at 11:34 AM (Merged)
FIXITMR
  • 9,990 POSTS
what motor?
KILMERONE
its a 5.7 vin#R
CHEVYFORLIFE
  • EXPERT
  • 33 POSTS
You could have a fuel pump bleeding down. get a pressure gague on it and turn the key on and then off and then see if the pressure drops very fast?
FIXITMR
  • 9,990 POSTS
no CEL on?
ZDIETRICH
  • 13 POSTS
97 Silverado 1500, 40,000 miles, 5.7L with auto trans,2wd.......Over the past month the truck has turned itself off (died) 3 times. All 3 times, I dropped it into Neutral and it re-started without a problem. The first time was at a red light, the next time was while going about 20mph, and the last time was while driving about 40mph. I don't notice the truck running rough or any other indications of trouble right before or right after it happens. I'm not real sure what is going on, but am affraid that eventually it won't re-start. Any ideas?
2CARPRO JACK
  • 11,533 POSTS
There were problems with the Crank Angle Sensors in those CPI engines. Caused no starts and intermittent stalling
ZDIETRICH
  • 13 POSTS
Not familar with a crank angle sensor. What is involved in repair/replacement? Is there a specific brand/type sensor you would recommend?
2CARPRO JACK
  • 11,533 POSTS
Should be in the bottom of the timing chain cover. Very easy to replace yourself
MAMALONSISIMO
Ive had this same problem 4 the last 2 years, i have changed the gas pump, distributor, crank shaft sensor and the problem has not gone away, the computer will not show faults. let me know if you have an answer for this problem and good luck.
ZDIETRICH
  • 13 POSTS
mamalonsisimo.....I'm going to start with the crank angle sensor and see what happens. hopefully that will fix the problem. I saw your post and see that you already replaced this along with several other things and you're still having trouble....thats no bueno...
CVG1MAK
  • 7 POSTS
I just rebuilt my chevrolet Chevrolet K-2500 350 5.7L T.B.I. V-8 out of my 1992 K-2500. The engine had locked up so I rebuilt from the bottom up. When I start the engine the idle is rough and only keeps running with assistance. After about thirty seconds the engine will die no mater what
Engine is in initial start up and break in phase of rebuilding.
New piston Rings, main bearings, rod bearings, TPS, oil pressure sending unit, cam bearings, new stock camshaft, lifters, valve seals, professionally cleaned all engine parts, qualified all non replaced engine components, new timing chain.
adjusted rocker arms, checked timing, verified vacuum hoses are in good order and correctly placed. crankshaft was professionally ground and polished to 10/10.
Oct 19, 2018 at 11:35 AM (Merged)
FIXITMR
  • 9,990 POSTS
have you done cylinder test to determine misfiring cylinders? i loosen wires at cap, start and lift them off 1 at a time to find cylinder that is not firing properly.
CVG1MAK
  • 7 POSTS
I have not checked, the engine when running is rough at idle, but does not sound like a misfiring cylinder, and that would not explain the loss of vacuum that does not recover, but I will check tomorrow to see if there are firing problems. Thank you and any other suggestions are appreciated.
MJSUMRALL302
When I first crank up I have to put I run it for about my foot on the gas and it sputters and runs hard like its missing. After I run it about twenty mins it so it starts idling fine until I turn it off. I try to crank it again right away and runs like trash all over again. Replaced plugs and wires and fuel filter and still didn't help. Please help.
BRIAN88FRED
k, i just put an engine in a couple years ago ran fine. about a couple months now. ive been having trouble with it. as it step on the gas it hesitates. when i let up on the gas lopes like i have a race cam and the oil pressure gauge will drop with it not much tho. i thought it was a IAC sensor so i replaced it. but its not that.
DRTFMR
Hi: Engine runs rough and misfires when accelerating. Idles fine. Changed fuel filter, plugs, wires, distributor cap and rotor. Thanks George
JDL
  • 16,098 POSTS
Hi, thanks for the donation. I'd use a gage and check fuel pressure. Any trouble codes? Your obd1, you should be able to access some mil codes, if there are any? If you up the rpms in park, does it act the same way? Sometimes, a high speed cut-out can be caused by a faulty coil? I can't be sure. I hate to throw parts at anything.
FIXITMR
  • 9,990 POSTS
so you did vacuum gauge test and there is a problem?
HMAC300
  • 48,601 POSTS
scan for codes an dcheck for a vacuum leak under tbi unit. spray with choke cleaner rpm will change if it is. also check your vacuum line leading otyour map sensor it sucks together and map can't get any vacuum. check your pcv hose as they get soft and do the same and pcv won't work check fuel pressure for tbi should be 9-11 psi
Have you checked for vacuum leaks? Not only the hoses but the intake too.
COUNTRY@HEART
  • 4 POSTS
Hello, I'm having problems with my 1989 Chevy Silverado 1500. This truck has 112,000 miles and I have kept it well maintained, but it dies while you're driving down the road. It has a propane system that I installed, but the problem occurs while running on gasoline or propane: the "service engine soon" light comes on, the engine starts running rough, like "dieseling", and a few minutes later the truck will die. If you pull over and shut it off until the engine is cool you can get back on the road and it's fine. It only has this problem once in awhile, not all the time, and I have checked and changed every filter, valve, and line I can think of. Computer codes didn't help, and I've been to 3 mechanics. The truck does burn a bit if oil in the exhaust when you fist start it, and the heat gauge reads at 210 degrees when it has trouble, which is a bit higher then normal even with plenty of coolant. Someone suggested to check a exhaust valve, or the distributor/ignition module. Any ideas?
OBXAUTOMEDIC
  • 3,711 POSTS
What you are describing is pretty instintive of the Ignition Control Module. And with that year it does not throw out any codes or turn on the engine light.
DRTFMR
I will replace the coil tomorrow and let you know the out come. Thanks George
CVG1MAK
  • 7 POSTS
Yes I put the vacuum guage on multiple sources when the engine stalled the first time and the reading is consistent. The engine has good vacuum for about the first twenty seconds or so, although it is fluctuating, and then begins to drop at a rapid rate to zero, where the engine dies. I have tried everything to keep it running but once the vacuum drops there is no saving it even at WOT. This caused me to check and re check the hoses and connections against the schematics, and everything checks out. i pulled the timing cover and re checked the timing which was dead on, and I re adjusted the valves/rocker arms too but the problem persists.
BRIAN88FRED
No, i replaced all the hoses. But havent checked the intake. Ive seen an easy way to check for vac leaks but cant remember Do you know of any?
COUNTRY@HEART
  • 4 POSTS
The codes that came up where all wrong, so that makes sense. But the light does come on. Could that still be it? Is it a "simple" fix? How much am I looking at to replace it? And is it something I can do myself?
Thanks for replying!
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
FIXITMR
  • 9,990 POSTS
EGR problem?
many people will use carb cleaner and spray it around the intake. If the engine speed picks up, there is a leak. Just be careful that you don't cause a fire.
OBXAUTOMEDIC
  • 3,711 POSTS
You would be looking at $80 - $100 for the part. It is mounted inside the distributor but you should be able to do the job yourself.
Before you do anything, what were the codes you got?
Depending on the codes and defs they could indicate another problem or lead me to something esle.
FIXITMR
  • 9,990 POSTS
pinch off brake vacuum?
