crankshaft position sensor?
2013 FORD F-150
143,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
BKSIMPKINS
Engine turns over but doesn't start and starter doesn't stop engaging. need a video to locate and replace crankshaft sensor.
Nov 24, 2019 at 2:22 PM
Good evening,
I could not find an exact video for this engine but I attached a picture of the location It is on the driver's side of the engine at the back by the flywheel.
Why are you replacing it? Do you have a code?
The other issues you have are not affected by this sensor.
It sounds like the starter solenoid is not releasing and the starter may need to be replaced. You should verify power is not to the solenoid when the key is in the on position.
Can we start with the original issue?
Nov 24, 2019 at 5:39 PM
ZACH RAMOS
So many places I've been told to find this sensor. Just trying to get a certain answer before tearing onto it. My truck has an EcoBoost engine.
Aug 3, 2020 at 12:09 PM (Merged)
Good evening,
The sensor is at the rear of the engine and works off the teeth of the flywheel.
I attache pictures of the location for you to view. It is number 7 in the second picture.
It's on the driver's side rear of the engine block where it goes through to rear from the flywheel. I attached two pictures. The first one shows several different components including the crankshaft position sensor. The second, I cut a section from the picture to get a closer look at the crankshaft position sensor.
Let me know if this helps.
ZACH RAMOS
Do I need to remove anything to get to it? Turbo?
No. It is a straight shot at it from under the truck.
GUAMECOBOOST
Did you end up doing it? How did you do it? Thanks!
JEREDALYE
Need to know where to find the crankshaft sensor and how to replace it.
The crankshaft sensor is in different locations depending on which engine you have (#7) Here is a guide to walk you through the steps and diagrams (below) that will show you where the sensors are and how to change them on your car. Disconnect the battery first.
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
We have not heard back from the customer at this time.
JOEJ88
I have a 2011 F-150 ecoboost 3.5 and got a code P0016. Is there cam and crank sensors accessible that can be changed out?
GUAMECOBOOST
Do you know the part number for this? I bought one from AutoZone, looks like a sensor but doesn’t look similar to the one on the back of the motor on the driver side I can see it right above the turbo? Thanks
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
That code is for the camshaft sensor 'A' which is the intake sensor.That is located at the top of the cylinder head on the right (passenger) side.Here is a tutorial showing what is involved in its replacement.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
I've also attached a picture below of what it looks like.Hope this helps and thanks for using 2CarPros.
Danny-
If you like, you can start a new question and we would be happy to help you.
JOEJ88
From the image you sent me, is this picture the back of the engine?
DANNY L
  • 5,648 POSTS
Hello again.
They are located on the front of the engine.Hope this helps and thanks again for using 2Carpros.
Danny-
JOEJ88
No it is not very helpful because the picture you sent me is of the back of the engine...
JOEY RICHARD
  • 7 POSTS
Need to know the location of crankshaft sensor.
CARADIODOC
  • 34,307 POSTS
Lower left side of the engine, way to the rear, under the exhaust manifold.
JOEY RICHARD
  • 7 POSTS
So this is wrong? because this is all I can find.
CARADIODOC
  • 34,307 POSTS
That's the same drawing I looked at.
JOEY RICHARD
  • 7 POSTS
So that would be by the starter and not on the front of the block? I have asked everyone and I a being told it is by the timing chain. so I do not want to take stuff off that I do not need to.
JOEY RICHARD
  • 7 POSTS
So what all do I need to remove to get to it?
JOEY RICHARD
  • 7 POSTS
Well if you have problems with the crank shaft sensor on your truck look on the driver side by your shifter cable there is one bolt out one nut take it out in there it is.
Hey,
Great addition to this thread! Please feel free to help out on the site whenever it can add information that will help people.
Best, Ken
CARADIODOC
  • 34,307 POSTS
I think you may have interpreted the drawing incorrectly. Certainly will not be the first time. It shows the sensor in the back, right where you found it. The people you talked with, (who obviously weren't as smart, and handsome, as I am!), were probably thinking about a different engine size.
JOEY RICHARD
  • 7 POSTS
The pic was good it just do not say what side it was on and trying to find it was a lil bet of a pain and come to find out it was the plugs that are all so a pain to change bc I have to take so much off to get to them on the passenger side but thank u to everyone that helped out
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
ANDYROO
as if I bought bad gas...the vehicle stalled intermittently then failed to restart.
intermittently means over 2 days and 150 miles.
at first fuel additive seemed to help, then after new filter, fuel pump and crank sensor total failure.
mechanic reports good gas, and pressure ok, acts as if wants to start
if successful i will return with payment...promise
thanks a million
andrew
Aug 3, 2020 at 12:10 PM (Merged)
BILLYMAC
  • 2,204 POSTS
Hi well this sounds like the injectors are not pulseing
which could be caused by ecm or eec relay blown fp fuse
one of these is causing injectors not to fire
BIXBYSTX
  • 7 POSTS
I put a new DSS crate engine in my truck about a year ago and the new engine has about 6,000 miles on it. I often get the P0315 code, which is the crankshaft variation code. My truck runs fine and I would think if my crankshaft sensor was bad my truck would probably give me some problems. Would putting a new motor in my truck trigger this code when nothing is really wrong with my crankshaft sensor? I have been told that Ford do not have a relearn like the chevys do with crankshaft sensors. I would like to get my problem fixed.
Thanks,
Brian
MMPRINCE4000
  • 8,548 POSTS
Either the sensor is sending the incorrect signal (wrong sensor, or wiring to it).
Or PCM is misinterputing signal.
Was engine from same year Ford?
Is it direct replacement?
Who installed it?
Hooking up a scanner to it in live data mode will tell you what signal the PCM is receiving.
During an installation this complicated is is very possible a wire as pinched, or connector pin bent.
Is this 4.6, 5.4?
BIXBYSTX
  • 7 POSTS
My motor is a 4.6 modular motor that DSS racing sells. I'm sure this motor would probably work on several different years for the F150. Yes this motor is a direct replacement for my factory motor. What type of scanner would I need to scan my truck in the live data mode? My engine was installed by S&G Performance in Tulsa, Oklahoma.
Brian
MMPRINCE4000
  • 8,548 POSTS
Actron, Innova, AutoXray all have scanners that will read live data.
They run anywhere from $200-$600.
If you get into the really GOOD scanners (OTC, Snap-on) you are looking at a minimum of $5000-$10,000 and up.
The less expensive scanners work fine, and unless you are a mechanic by trade, are generally overkill for most people.
SCOOPI321
  • 12 POSTS
first I had to replace the alternator then the battery ends, and now I had to buy a new battery, well it started twice and on the third time as soon as it started, it quit, my question is : could this be the crank shaft position censor?
I bought the truck in October last year only to find out later that it has been totaled and rebuilt. with a rebuilt title. nice huh? then the oil pan gasket had a leak so the seller charged me $390. to repair that,
we have had problems with the battery cables needing cleaned and disconnected and reconnected, then after all that we got it started and running and it sounded like it wasn't getting gas. so I hope this info helps you to understand the truck so you can help me. sandra
Aug 3, 2020 at 12:11 PM (Merged)
HMAC300
  • 48,601 POSTS
you'll need to scan for codes and check fuelpressure with a gauge first to see what is wrong if anything to not start. also check fuses underhood in underhood fuse box. autoparts rent the gauge
SCOOPI321
  • 12 POSTS
checking codes with a scanner is fine, except I cant start the truck to get to the auto store. and also I had popped a coil out to see if im getting spark, and there is no spark.
HMAC300
  • 48,601 POSTS
see if autoparts will rent it without scanning you don't know what is wrong. you can test to see if crank sensor is getting voltage and maybe resistance of it bu tthat won't tell you much at all. check fuses underhood aswell and if it has a anti theft which it may reset it lookonline for that.
SCOOPI321
  • 12 POSTS
what would the theft device have to do with the truck starting or not. now I talked to a mechanic and he said it is definitely the crank censor. by the way I do have power to the fusible link and the coil, but I didn't get anything at the censor, with key on and off, maybe it has to be running to get power at the censor, you think?
HMAC300
  • 48,601 POSTS
depending on the model if the anti theft is activated it may not send power to the ignition system or fuel system or both. But you are sure it 's the crank sensor have at it.
