The heat on my driver’s side sometimes stops working - blend door actuator?
2015 CHEVROLET TAHOE
65,000 MILES • 4WD • AUTOMATIC
Is it dual climate control? This guide will show you which actuator does what:
Sep 24, 2020 at 10:32 AM (Merged)
MRMGREENE
  • 14 POSTS
Roy it worked! I cannot thank you enough. I cannot wait until I have another question.
SHPAIGE24
Yes it's dual climate control. I was driving one day and the air went from cold to hot. I took the actuator off right below the glove box. Kind of easy to get too. I took it apart just a little bit not all the way. I see a whole lot of greasy build up inside of it. Didn't want to take it apart just in case it was the wrong one. Checked all fuses. None are blown. Turned on my rear a.c. in my truck and it blows heat as well. Also how will I know if it's the a.c. compressor itself? The heat and defrost works fine.
You are welcome.
If you turn the AC system on on open the hood you should be able to see the compressor clutch turning. here is a guide to help you see what I am talking about:
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
MRMGREENE
  • 14 POSTS
Roy, I was driving today and noticed the heat is only working on ninety degrees again on both sides. Perhaps my check was not good enough. I pulled the fuses again and verified the system reset and still have the same result. When i go from ninety to eighty five for example i watch the actuator click and keep moving until it is wide open more or less. I am wondering if it could be anything besides the control unit itself which i can get on eBay for $160.00. Before i broke out the parts shotgun i wanted to see if you thought it could be anything else besides the control head unit or the actuator itself. Thanks again.
Okay, the blend door actuator could be the issue but I know it is new.
yes, it could be the control head.
Is the temperature sensors reading the correct temperatures? inside and outside on your control panel?
MRMGREENE
  • 14 POSTS
When you say outside are you referring to the temperature sensor that senses the outside temp and displays it on my climate control panel? if so, yes it displays the correct temp outside. Regarding the inside temp sensor, i am familiar with the sensor by the driver head, but I was unsure how to check the sensor.
Does it display the inside temp correctly?? when you set the temp it will change according to the need whether heat or cool. if it does not change then it may be the issue.
MRMGREENE
  • 14 POSTS
Thanks. I was told this can be caused: by a fault with an internal air temp sensor. If you have an air temp sensor that is sensing the interior is hotter than it actually is when you set the heat, anything but 90° it will keep cool like this. When set on 90° this bypasses the temp sensors and it blows full hot no matter what the temperature is inside the vehicle. I have seen this type of fault before and it is usually a temp sensor failure causing this needing replaced. Question is, how do you test the sensor to confirm if it is bad?
I read this and it sounds like a match, im going to look at it
you need an advanced scan tool that can rad the ac module and read the info. you cannot see it otherwise.
MRMGREENE
  • 14 POSTS
after further investigation it looks like it is going to be the sensor. Thank you for telling me about that. I am going to work on getting it out of there.
You're welcome.
your welcome
MRMGREENE
  • 14 POSTS
I took it out and ordered a new one, I had voltage at the plug so hopefully this works. I definitely learned something.
okay, sounds like a plan.
MRMGREENE
  • 14 POSTS
Roy, I replaced the sensor and it fixed it. Would have never known to look there without your input, thanks again I really appreciate it big time!
no problem, glad you got it fixed.
MRMGREENE
  • 14 POSTS
OK, the tool is only available when you buy the kit. you do not need this.
Attached is a picture of the tensioner. you need a 3/8 ratchet to release the tension.
MRMGREENE
  • 14 POSTS
My set up does not have the tensioner so I have to work the belt on with zip ties I think. I was just curious if this tool helped get the belt on somehow when there was not a tensioner present.
That is what I got for yours. Can you post a picture for me or what you have
MRMGREENE
  • 14 POSTS
https://www.youtube.com/watch?v=wmzhzxh8XhY this is a video of my situation
LOT
For anyone in the future.
This was the only helpful hit on Google I could find for my 2011 Yukon's rear A/C where the actuators are hidden. (BEHR)
The part number for both actuators is 15887322.
May 18, 2021 at 2:01 PM
DANNY L
  • 5,648 POSTS
Thank you!
Adding this to the thread may help someone in the future that is having the same issue with the same type of vehicle. We hope you will use our site again in the future when needed. Thanks again for using 2CarPros.
Danny-
May 19, 2021 at 3:06 PM
