fuse diagram not one in the user manual?
2017 VOLKSWAGEN JETTA
45,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
Since it is working (somewhat) when it is in park, I have a feeling the problem may be in the lamp position module for the left side.
I attached the wiring schematics for the exterior lighting system. I highlighted the wires related to both the left and right parking lights. Additionally, the last two pics show the module I am referring to. As far as the delay, it can't be a ground issue because the brake lights use the same ground location and they work properly. So, I suspect it could be the module. Also, the j519 module (electronic control module) may be the issue.
If you haven't already, you may want to consider performing a scan of the can-bus system. CAN stands for controller area network. Basically, all the modules/computers are tied together via a few wires. If there is a failure in any of the modules, this procedure should identify it. Here is a quick video showing how it's done. Note: When this is done, we need to pay attention to the J519 control module for codes.
https://youtu.be/InIlnsjOVFA
If possible, have that done. Hopefully, it will identify a code that is related.
Take a look through the schematics below. I had to cut them in half to make them readable for you. I did, however, overlap them so you can follow from one to the next.
See pics below.
Apr 29, 2021 at 8:16 PM
RYAN BROWN
  • 6 POSTS
Thanks for the update Joe!
We did get a scan performed at AutoZone - but I’m not sure if their reader only detects engine problems? The scanner in that YouTube video seems much more high tech. Are there places that rent them - or where should I look to have this sort of scan performed? I think you’re right about it being a module issue. This seems like we’re at the stage where I should have a professional look at it? I’m a little out of my wheelhouse past the point of changing bulbs or fuses.
Apr 29, 2021 at 9:31 PM
Chances are you're right. Oftentimes, a parts store will have a scan tool that can only read powertrain codes and nothing more.
What I would suggest is to see if there are any shops near you that can scan it. Hopefully, someone will do it for you free of charge, but in today's world, that may be expecting too much. LOL
Apr 30, 2021 at 6:34 PM
