Battery Parasitic draw test?
2004 MERCEDES BENZ CLK500
145,000 MILES • V8 • 2WD • AUTOMATIC
AL514
  • 5,465 POSTS
52amps to 23amps? A half amp draw is high, but I expected it to be much higher. How many times has the battery been charged and fully discharged?
Dec 15, 2023 at 12:32 PM
BHAMDOC1973
  • 2,008 POSTS
Twice, but it's still strong. Starts from first time once charged. Yes, i thought it will be higher.
Dec 15, 2023 at 12:35 PM
AL514
  • 5,465 POSTS
The aux battery might be discharged as well though, but really the current draw on these vehicles goes down to about 0.016A(16ma) when the entire vehicle goes to sleep. Thats what I have seen before, but you want it to def be down below 0.050A. 50ma is the max I think a vehicle should be pulling after power down. And if you see it fluctuating that might be other modules waking up because of activity on the CAN bus, Most CAN bus modules send out a data packet or type or ping letting other modules know they are on the network, and when other modules don't see that message, they will set a U1000 code for the module they are not seeing, It's kind of a telling on each other code. But that amperage has gone down. The Aux battery is going to draw off of the main battery too when the main is hooked up after being charged, so something to keep in mind too. I know those aux batteries are pretty small, but they will still try to equal out with the main one as much as possible. I think you may find that there is more than one fuse that has a voltage drop, because of multiple modules being awake. This is why I'd be monitoring the CAN bus signal as well. With a draw like this, in some cases you will see part of the network go to 0-volts, but then another module sends out a message and other modules become active on the network again after having gone to sleep. These are some of the most difficult diags to do.
Dec 15, 2023 at 12:49 PM
AL514
  • 5,465 POSTS
You might want to watch these two-part videos again, since this is a Mercedes with the same CAN bus multi connectors.
https://www.youtube.com/watch?v=5OE3CYNSVNI
Dec 15, 2023 at 12:53 PM
BHAMDOC1973
  • 2,008 POSTS
When the aux battery is discharged on these you would get a message, had several replaced in past years. Yes, I am sure there is more than one fuse. I only checked the interior one, have not yet done trunk or under engine.
Dec 15, 2023 at 12:56 PM
AL514
  • 5,465 POSTS
What's the charging system voltage when it's running? You can also measure the amperage coming out of the alternator on the main cable with an amp clamp.
Dec 15, 2023 at 1:04 PM
BHAMDOC1973
  • 2,008 POSTS
I checked the charging before, even with the bad battery, its 14 some, no codes, no check engine light, you can drive it all day. I suspect the tele aid as these old ones always have a problem with these, but like u said there are tons of modules and it's hard to diagnose, even when asleep something may wake up. even with latches closed lights won't go off in the interior because those 2 plastic push must be pushed back and there is really nothing, I can use to keep them in, tape won't hold it, a vise won't hold it, even those windshield clamps didn't as its far from the interior pillar, ugh.
Dec 15, 2023 at 2:14 PM
AL514
  • 5,465 POSTS
Something else you should invest in is a thermal camera, it can show you any modules that are potential current draws real fast, when radios or clusters are staying powered up, they show up glowing bright, it can really help with finding a draw or at least narrowing it down much faster than going through all the regular testing methods. Just something to think about, I know you go through a lot of vehicles. Even a small one like this will be a huge help. Start watching some of these YouTube videos as well. This tech, Jake, the one who is doing those 2 Mercedes videos has a ton of great videos if you look on his YouTube page. He is super smart and deals with these type vehicles all the time.
This is his link:
https://www.youtube.com/@autodiagyt/videos
Dec 15, 2023 at 2:30 PM
BHAMDOC1973
  • 2,008 POSTS
2 fuses had a lot so i pulled them both and left it to sleep again. It was showing 0.81 under the 6-amp selection on the clamp, now its 0.31. Going to leave it for a few hours. I left it an hour locked and checked battery and it had same voltage no drop before i said the fuses, I'll see how ping it will take.
Dec 15, 2023 at 2:57 PM
AL514
  • 5,465 POSTS
You can check for voltage at the DLC, pin 16 is B+, 4 & 5 are still grounds, 6 & 14 are Interior CAN bus High and Low, the rest are labelled on the 1st OEM diagram, not sure how accurate the aftermarket one is I marked out in the 2nd diagram. But 6 and 14 should drop off to 0volts when it goes to sleep. I'm not sure how many CAN bus networks there are in total, since it looks like there are other diagnostic connectors possibly in the vehicle.
The label 6A on the amp clamp just means it will read up to 6amps on that setting, it's for accuracy if you need to measure higher amperage circuits.
Dec 15, 2023 at 5:33 PM
BHAMDOC1973
  • 2,008 POSTS
So far overnight it has dropped to 12.25, which is a good sign. I need to find out what those 2 fuses are for first. Seems like more than one fuse is drawing current, but they also could be for one system. Can you get me the diagram for the fuse box with labels as none are found in the car or on the fuse cover?
Dec 16, 2023 at 4:02 AM
AL514
  • 5,465 POSTS
These are the aftermarket power distribution diagrams, the OEMs are pretty difficult to read, but if something is missing let me know. The aftermarket info is not always full.
How many fuse panels are there in the vehicle?
Dec 16, 2023 at 10:47 AM
AL514
  • 5,465 POSTS
These are the OEM diagrams for the interior fuse, and it looks like modules as well which offers coordinates to each component on the diagram. They look like they're designed more for engineers than technicians. But in case you need them, I will check the others as well. I think there's one more set with fuses.
Dec 16, 2023 at 11:03 AM
AL514
  • 5,465 POSTS
These are the oem Front Back Up Fuse Box components, there are lists of connectors as well, they all look like this, you mentioned hearing a noise in the dash as well, check for a CD changer in the glovebox. Theres supposed to be one in there, maybe that has a CD stuck in it thats staying active. That happens pretty easily.
Dec 16, 2023 at 11:12 AM
BHAMDOC1973
  • 2,008 POSTS
Yes, i think i saw a CD changer. I saw 3 fuse boxes, under hood, on driver side, and in trunk.
Dec 16, 2023 at 3:41 PM
AL514
  • 5,465 POSTS
try unplugging the cd changer, unless it's functioning okay. But it seems everyone I've ever had ended up with a cd stuck in it. But the Radio is on the CAN Bus and also has a right and left amplifier modules (so more computers to stay awake), an Amplifier module 2 Screen Antenna, an AM Trunk Lid Antenna amplifier, Emergency call system control unit, etc.
These are the OEM diagrams for the Radio, there are 7 modules that are linked to the Radio circuits.
Dec 17, 2023 at 12:40 PM
BHAMDOC1973
  • 2,008 POSTS
I disconnected it and will keep battery monitored for a few hours. Also, the noise I was talking about lasts for 10 seconds behind the dash, definitely a door blend or an actuator. Will see if the cd changer does anything. I'm not sure if the seat/wipers/power tilt not working is contributing to this issue. Not sure if they share same fuse or module.
Dec 17, 2023 at 1:31 PM
AL514
  • 5,465 POSTS
What 2 fuses did you pull that made a difference so far?
Dec 17, 2023 at 1:33 PM
BHAMDOC1973
  • 2,008 POSTS
Just saw a video on YouTube this guy went fuse by fuse identifying what they are for. Turned out the seat/tilt and wipers fuse were not there, installed one and they all started to work.
Now the noise behind the dash pulls current while it's doing it for 10 seconds but once it stops the current drops from 0.8 to 0.4. Also, he pointed to a teleaid fuse which i removed and the current dropped to 0.14. The 2 fuses that dropped the current before were this teleaid and the cluster fuse. But i can't have the cluster one removed as the cluster goes dead. Left telaid off and will monitor how battery does in couple of hours.
Dec 17, 2023 at 1:54 PM
BHAMDOC1973
  • 2,008 POSTS
In half an hour the current draw went down to 0.03, praying this is going to be it. Ce changer still disconnected.
Dec 17, 2023 at 2:16 PM
AL514
  • 5,465 POSTS
If you're down to 30ma, that's pretty low, I doubt you'll get it any lower. If you put those other 2 fuses back in and the draw stays down, I'd think the CD changer is at fault.
Dec 17, 2023 at 2:32 PM
AL514
  • 5,465 POSTS
So, where are you at today for current draw?
Dec 18, 2023 at 8:42 AM
